What hardware to replace when replacing bushings
Lawrence KS
So I have read that some of the hardware (nuts, bolts, and washers) are one-time use only and should be replaced when working on the control arms and whatnot. I have plans to replace all the worn-out bushings on the front and rear. Trying to figure out what I need to order. After reading the FSM it only states to use "new" hardware on the front control arms. Are these the only pieces of hardware that need to be replaced as one-time use? And is this hardware really one-time use? Has anyone out there had luck re-using the original hardware? I already did my front track bar and had no issues re-using the original hardware.. Seemed to torque down just fine.
Thanks!
Thanks!
I will tell you from my recent experience, I DID buy all new hardware. I did install all new hardware.
I really don't think it's necessary. I bought it all in case I broke one or needed something. To me that was a $100 insurance policy that I could complete what I started at whatever time of day / weekend that I started.
If you need a bolt, let me know and you can have my old one(s).
That being said, I WOULD buy the tiny bolts that hold on the swaybar bushings (all points) and the steel bushings that go on those swaybar tips.
Don;t waste your money for the majority.
I cannot believe we didn't talk about THIS when we were working on your front panhard bar.
BTW: Do you feel an improvement?
Fsm indicates one time use items with a diamond. Its mostly the nut side. However if you spin off the stakes on the bolt flange it may benefit from replacement. FWIW ive reused all the OE hardware and just finished the last of a whole suspension bushing kit from akella. No issues here
Hey Mark..
Thanks for the offer and I'll most likely take you up on it if I end up needing a bolt.. And yeah I kept forgetting to let ya know the new bushings on the track bar seemed to help a bit.. Still feels a bit loose, but better. Next time we get together I need to let ya drive mine to see how it feels compared to yours..
We never replace them, but, don't have rust issues. On all of the arm/panhard hardware, only turn the fastener with the washer, never the end with the flange.
