What else??
Mineola, TX
Hey everyone,
I've got a couple of leaks to work on (valve cover & pan arch), so I've added a few "always good to get done" items in there. What else should I do while I'm at it.
Here's what's on tap so far:
1. Valve cover gasket (and compulsory TB gasket)
2. Sub pan fipg
3. Main pan fipg & pan arch
4. Plugs
5. Wires
6. Distributor cap
7. Dizzy rotor
8. Belts
Well, there you go. What else would be handy to do at the same time??
:cheers:
I hate to say it, but that amount of gasket replacement puts you in close reach of the important gasket, the head gasket. If you have the valve cover off and the dizzy out you are halfway home, bro.
hahaha
he wouldn't be very close to home, but that same logic worked on Beno:p
...and why remove the dizzy?
2. Sub pan fipg
4. Plugs
5. Wires
6. Distributor cap
7. Dizzy rotor
8. Belts
this is a good amount already, but what about the hoses and vacuum lines?
hahaha
QUOTE]
Actually, it's further than you think because the part that takes the longest is the fear and trepidation involved in deciding to do it. Reread the post and saw he's only doing the rotor, not the o-ring that leaks.
Jason,
Are you doing this at Javiers? I am assuming the pan arch will be done using the tilt the engine approach.
Buck Buchanan
ps have fun at the Jamboree.
Hey Buck,
Yeah, did it at Javiers. I got all the top end stuff done. One FUBAR, though, I ripped the hose that goes from the airbox to the throttle body in half and had to get another one. 75 bucks!! :doh: Runs nice w/ all new plugs, wires, cap, and rotor, though. :grinpimp: Just gotta do the pans on Monday now. Then I'm good to go.
