What does this wire do?
I don't recall seeing this little wire above the bulb with the ring terminal on the end last time I had the cover off but does anyone know what it is or why it's there? Is it a ground?
DC elektrickery needs a +ve and -ve. Since the housing is plastic, a wire (the black crimped ring terminal) is used to provide the -ve elektrickery to the metal plate and hence to the bulb's base. The grey wire carries the +ve elektrickery to the nubbin of the bulb which is switched. When both are active the filament of the bulb glows :)
And yes, that black wire was there when Mr T built your 80.
cheers,
george.
Hmmm... Couldn't tell from the pic I found that the ring was anchored down to the metal plate. It looked to me like it was just hanging there in limbo. It may be a ground but for some reason I couldn't get my LED to light off of it but it did light on the two big mounting screws that hold the whole unit in place.
So I got my narrow angled overhead triple red LED mounted to the base of the rear view mirror so I can see inside the "cockpit" without breaking my night vision. I'll jump in the truck two or three times a night to fish another section of beach and this way I won't need to flip on the overhead bright white light.
The black wire IS the ground for that bulb - there's no "it may be a ground...".
Here's a picture that I took 10+ years ago when I installed LEDs in my maplight fixture.
cheers,
george.
Well I pressed the ground wire on it a few times in a row and then went for the screw. A horseshoe spade connector on the screw worked out perfectly. It's recessed so the spade cant slip off.
