What did I screw up?
SE Idaho
As part of my desmog I took my air rail out tonight. After I got everything put back together, my truck will not idle, and my choke won't move. I ran out of daylight before I could tear it back apart. Anybody have any ideas?
Intake manifold leak somewhere is my guess.
I guess I should also state that I used the little allen head bolts from Jim C. to plug the holes, everything went pretty smooth but that last one by the firewall is a real pain.
What do you mean "Choke won't move"?
Choke knob won''t pull out?
Choke butterfly cannot be manually closed?
Choke butterfly is stuck shut and won't open w/ hand pressure?
Look at the choke cable under the hood. somewhere between the firewall and the connection to the carb it's prolly gotten kinked or jammed in an uncomfortable corner. Most likely somewhere in the neighborhood of where the air rail removal was happening.
Thanks Jim, that's what I was thinking, but I ran out of daylight, and when the sun went down, so did the temp. I'll check it out tomorrow when I get back from skiing. If anybody else has suggestions, I'm still open.
Thanks
Ok guys, still having a problem. I traced the choke cable from the carb to the firewall, and back again, probably 12 times, there are no kinks or snags or anything else unusual. But it still won't pull out from the dash. I'm befuddled. I've got no clue. If I can't fix it this afternoon, I'll post a pic maybe one of you will see what I didn't.
Currently, it leaves the firewall, hooks a right and follows the firewall then starts heading out into the engine bay under the air horn that hooks around to the carb. Sound right?
When you take the choke cable loose from the carb, does the carb linkage work?
All of the linkages seem to be in working order. All move freely by hand with no issues. What do you mean by "take it loose"?
Question is............did you remove the choke cable at all during your work on the air rail?
If you did it may be re-installed incorrectly and the clamp(on the carb) is pinching it and not allowing it to move...........
Waht he means by 'take it loose' is undo it from the carb and check choke linkage movement...........
I never did anything with the choke cable, at least not intentionally. I didn't remove it, I worked around it, and didn't have an issue at all. I will try to get it all loose from the carb this afternoon after work (if there is still daylight when I get home) and see if that is the issue. If nothing else, I should be able to identify if the resistance is coming from the carb, or somewhere further down the line.
Thanks for your help guys.
there is not much to stick on the carb side... the choke plate is always up and down and turns down against a spring so it snaps back into the up and down position. It's only turns 90 degrees. I bet the cable is snagged on something.
Wow, I wish my carb looked that pretty. That picture actually helps a lot to visualize what is going on back there, without removing my carb (it's not the easiest thing to get to in the engine bay). All of the choke linkage moves just fine by hand, (I just went and looked in the parking garage at work) when I move it by hand I can see slack develop in the cable, but don't have a flashlight with me, so I can't see if it is binding right there or not.
