- Joined
- Jul 20, 2003
- Threads
- 110
- Messages
- 1,845
You (or PO) didn't remove the "they say you can run without it" C-clip on the birf end did you? It can allow the shafts to get pulled toward the third member allowing the seal surface to get pulled away from the correct spot on the shaft. Did that make sense?
Anyway you need the C-clip or some people place a spot weld at the end of the birf shaft so it doesn't slide in as much. Makes changing a birf in the wilds easier.
