E-locker is the Toyota factory locking axle option that is mostly misunderstood by the public. It locks the axle differential when traction is lost by one wheel, and foreward motion is lost. It is the option that makes the 80 series LC the king of factory-built off-road trucks.
If you rarely leave pavement, and only then in mild situations, it is worthless to you. If you find yourself in severe situations, it may be priceless. It is to be used only by knowledgable persons in extreme off-road situations. The misuse of the option can result in axle damage, especially when the front locker is engaged while turning. Use of a locking axle is rarely helpful on ice. It is more often a detriment in such conditions. A locked axle will promote sliding on icy surfaces.
Think of the "positraction" on old muscle cars. Those cars would refuse to turn corners. The locker does the same thing in a 4 wheel drive. When a locker is engaged, the truck will try to go straight. It will not turn easily. When turning with the locker on, you risk axle breakage.
When oversize tires are installed, there is some risk involved in the use of a locking axle. If you want to be involved in the use of a truck in rough country, a locker is invaluable. But it may have a cost. It could break costly components.
Land Cruisers with the locker option were imported in limited numbers. Finding one in clean condition that is for sale is rare. Trucks with lockers are more rare and valuable than others. But locked trucks come with all of the requirements of user knowledge noted above.
The 80 series Land Cruiser in unlocked form has an uncanny level of traction. It will grip the dirt with uncommon ability without lockers, even on street tires. A locker equiped LC operates in the unlocked form at all times except for when you choose to engage the lockers. When the switch is on, the truck is locked.
When the truck is locked, the tires will skid on pavement, and may bind up. This places a lot of stress on the gears. Use of low range or lockers is not a good idea on pavement of any kind.
The proper use of a lockable truck will require that you school yourself on the proper use and maintenance of the truck. Read this and similar sites to learn. If you have access to one that is available, and you want to own it, more power to you.
I would say, buy it, and then read here to learn more.
