what about this idea?
Socal/ I.E.
I am thinking of rerouting my cads so they dont hang below the bottom of my 80. then when I get sliders I can save some $ by getting solid rock sliders or some other slider that dose not have a cad protection system. what do you guys say?
my running boards have been removed.
I also want to know if I can turn my cads 90 degrees without any problems?
Do you mean cats? Catalytic converters?
If so, good luck.
I would leave them alone and just pay the extra dough for protection. Just my $.02
Skillet x2. It would probably be a lot more costly to start messing around with the configuration rather than just protecting whats there.
One reason that comes to my mind is the heat that comes from the cats. If you were to go cross-wise with them, however that would work I have no idea, but you would have a lot more heat issues to deal with. Another issue might be O2 sensor issues - placement, wiring to and from, etc. The length of wire TO the O2 sensor is calculated into the engine controller because it has to understand the resistance in the wiring. You change that and maybe could screw up the signal to the ECU, or maybe have a perpetual Check Engine Light.
...don't want to discourage innovation, but don't do anything haphazard to save a few bucks on a little steel protection that's already out there.
good luck.
hawkeye- I believe quite a few people with the 95-97 cat config. have successfully rotated the cats with no problems (and no wire length mods). Some have placed heat shielding above the cats and below the floorboard, IIRC. Hopefully they will chime in or their posts will come up in a search you might want to do.
I did the cut and turn mod on the cats and have had no heat issues, i did it about 4 years ago when i went with a custom cat back system. there plenty of room to turn them 90. I can post pics if any one wants them
Whoa, my bad. I misunderstood your intention. I pictured you re-routing & relocating, not simply rotating your cats. That's been done with good success.
You're in California, so be careful when it comes time to smog your rig that you've done everything above board so you don't get snagged by the smog nazis. They're gettin' tighter and tighter!
That is how I read it as well. Complete relocation.
I didnt mean relocate, I simply meant rotate. And that is my bad on the "cad" skillet, of course I mean Cat. what about the tube style cat, does it give enough room, so that I dont need cat protection?
Hawkeye,
Sorry to rehash what I've already said, but if your location is "cali", meaning California, you have to be very picky about your cat set-up or the smog inspection won't pass. Most muffler shops won't even install what wasn't on the vehicle to begin with, and unless you find a less-than-honest smog shop, it won't pass. Again, they're pretty diligent.
You pretty much for sure need two cats, and if I believe the stories, if the cats look new, a smog shop may look to see if they're OEM, which I think is actually required. Admittedly an unlikely scenario, but just be wise to the whole process and you'll be $$ ahead.
Back to your original question, I think that even if you do rotate them and tuck them up nicely, it would still be smart to provide some protection for those high-dollar pieces!
Post up and let us know what you do. If you're so.cal. / near south bay, I've got the name of a pretty good shop that has done work for folks on here before.
If "solid rock sliders" is Solid Rock Off-Road, then you will get cat protection from their sliders.
