what about headers?
Socal/ I.E.
Hey guys, Im wondering about installing headers on my 97 80. I wanted to know if anyone has headers without a supercharger. what is the difference in MPG. and HP. and is it a CA legal mod. thanks guys.
I found a set on ebay from the folks down under. Pretty reasonable too. I am just not sure of Customs and such. Even if they don't have an 02 bung, a decent shop can wield one on. If anyone wants the link let me know and I will P.M. it to them.
BTW the cost is 367.00 US before shipping.
The past concensus as I understand it is that the stock exhaust system is designed pretty well, and headers don't do much if anything for performance, while sending more heat into the engine compartment. There's been a few threads about it, you might search if you haven't already.
-Spike
Agreed on the minimal performance. The most I would do personally is a high flow cat and low restriction muffler. Both are covered in the FAQ page. Other than that....until it falls off my truck, that is where it will be (stock).
Kevin
I wouldn't bother with headers.
If you do a bit of searching, you'll come across a situation where M-A-F headers for the 3FE actually began melting everything within three feet of them. :eek:
PS- Performance gains on that same truck were minimal.
From my actual experience I would have to emphasize that headers done right on a 1FZ absolutely will add significant power. The speculation that headers add little or no power is associative at best and ultimately false.
Headers done correctly on any vehicle will add power over short, cast iron exhaust manifolds. Reducing restriction without killing velocity after the collector (or before the head intake) will also contribute to better performance.
i too had wanted to find this out. i had previously read about the heat problems, but had planned on heat taping the crap out of the headers to help divert the heat out of the engine bay. i know some will say " no! you cant tape headers, they will rust and blah blah blah...." so go ahead and object. but i have taped headers on a slightly built camaro, and a couple slightly modded subi's, and it does help the heat quite a bit. the camaro headers were on for 4 years and when we yanked it all back apart there were no signs of any rust or rot problems with it. in the normally dry climate of colo i have really seen no problems, and i hope it wont be any problem when i move to phoenix next week.
just my .02
Do you have dyno numbers before and after the headers?
-B-
-B-
No dyno runs, but I have raced several stock FZj80 Land cruisers on tires ranging from stock to 33s and the difference in acceleration is significantly obvious. I am much quicker and I am on 35s with stock gearing. Go figure.
I may get more interested in doing a dyno run after my performance head is complete, installed, and I do a gear change.
If you decide to do headers, I would wrap them with exhaust tape... take no chances on under hood heat.
Bad idea, exhaust tape will trap moisture against the headers and promote corrosion. A header blanket would be ok, but not neccessary. I wouldn't wrap anything with exhaust tape that you aren't prepared to replace within a few years. Except for stainless steel which already does a very good job of heat retention.
Ceramic coating would probably work well to control the heat/minimize corrosion and you wouldn't add any down time if done before initial header installation.
No dyno runs, but I have raced several stock FZj80 Land cruisers ...
And I take it all of these Land Cruisers were blowing your doors off prior to the time you installed the headers?
-B-
-B-
I make the safe assumption that the performance of one stock fzj80 is similar to that of another. Then throw in my 75lb tires with larger diameters and I should be at a definite disadvantage rather than being able to pull away with long legs. Seems like a reasonable assumption that is at least based on something quantifiable rather than "I just think that the exhaust on an FZJ80 is the best it can be so no reason to waste your time with headers".
Not true.
A friend (Rudy) has a '97 40th like mine but with 33's and stock gearing. I have 4.88's and 35 Toyos like yours. Neither of us have custom headers. My truck has the LT MAF but is carrying more weight. Rudy could pass me like I was sitting still when pulling a grade and I was WOT and ~60mph. It wasn't even close.
Another friend (Rory) has a '97 poverty pack with 35's and stock gearing. His drives like it is on stock 31's and will also blow the doors off mine from a standing start. Rory's truck had a recent HG job. Rudy's is original HG (as far as we know) but low miles (~95k).
I have driven other 97s that have similar performance to mine... nothing noticeable one way or the other so I don't think mine is a total dog. I have also driven a 93 with 35's and 4.88s and the performance was very similar to mine.
My point is that there can be significant differences in performance between otherwise identical vehicles. If you had raced these same trucks before the headers and lost or no difference, then raced them again after the headers and had a significant advantage over both trucks then maybe you could draw a conclusion. As it is, all you can say is that your truck is now faster than theirs and it was probably faster than theirs before the headers. We'll never know.
-B-
-B-
That holds true on both sides of the equation. Nobody can stand up and say that headers are a waste of time if they haven't installed headers properly and then compared. I know there is a positive difference from my seat of the pants meter aside from any comparison to other 80s or other vehicles in general.
It is a known fact that a well designed header exhaust with a good Y or X will provide better flow into the combustion chamber during overlap. My point is that there is no quantifiable consensus among Land Cruiser owners that headers are useless on a 1FZ. In fact, I am part of the general consensus found in the racing community that any four stroke engine can create more power with a well designed tubular header exhaust system. Especially a twin cam motor.
Sounds like you are pretty sure you think you know the truth there tiger. Guess you don't need a dyno before you stand up and assert that you think that headers are useless. I am 100% sure that you are wrong. ;)
I have not said headers are useless and I challenge you to find any of my posts that say that.
You made the claim that your headers "absolutely will add significant power." I asked if you did before and after HP measurements using a dyno which is pretty much the industry standard for quantifying engine improvements. You countered with your seat-of-the-pants impression and anecdotal observations (street race results.) Sample size = 1.
I have no opinion one way or the other on the benefit of headers for the 1FZ-FE but I was hoping you had done your homework before you made the claim... that is all.
-B-
You may have not verbalized that exactly, but you did imply that by stating that any power advantage present was probably not related to my upgraded exhaust. Leaving one to deduce that you are identifying my header exhaust as absolutely ineffective in contributing to better performance despite the lack of your precious dyno results.
So then call me a liar tiger. I am still saying that my power gains were significant. Anyone saying they weren't has even less on which they base their opinion (that includes you ;)).
and it was probably faster than theirs before the headers.-B-
I have no opinion one way or the other on the benefit of headers for the 1FZ-FE.
-B-
Sounds like an opinion to me. You got dyno results?
Why do you keep trying to bait me into calling you a liar? As I said, I was hoping you had quantifiable data to back up your claim but since you don't that is OK. You like your headers and that is OK too.
:cheers:
-B-
:cheers:
-B-
No dyno charts, but I am currently accepting donations for that purpose. Meanwhile, I have no qualms with stating that a well designed header exhaust can absolutely improve the performance of a 1FZ. It doesn't bother me that you think I am delusional for thinking so without dyno results.
