What a trip so far...
Jefferson City TN
so a few of you helped me with the power steering going out the night before our cross country trip. Got that fixed. We then proceeded to drive through the night. At around 3am we stopped for gas and I got out and smelled gear oil. Looked at my front third member and the top was covered in gear oil. Then I noticed the top had a 1/8" or less gap between the housing and 3rd. I just had the thing in the shop for a pre trip look over and I was on a 2 week Michigan trip about 3 weeks ago. What could cause a 3rd to creep back? I got it all torqued down and I will be checking it when we stop shortly again. Fluid leak has almost totally stopped. Never seen it. Every nut was loose.
Next thing is driving with a/c all night on and my floorboard on the passenger side became a swimming pool. Again out with the tools and cleaned the crap out of the drain and evap box.
I am at a loss, I maintain this thing like crazy. Even prepared and went over it myself and had a shop do it.
Hopefully I won't have any more issues and can enjoy off-roading in Colorado.
Simply put the 3rd wasn't tightened/torqued. The top of the third gets the most push/pull because of the pinion. Doesn't take long to get the results you experienced.
Been looking for torque spec but haven't found it in my exhausted mindless state. I tightened everything up pretty dang tight. Was careful not to over do it though.
I will also note that I am fully loaded with 6 of us, full fridge, gear, trailer, 2 RTT's and enough off grid stuff to live full time and the cruiser seems to be holding aside from the above mentioned items. Thanks to my modified fan clutch and aux fan I haven't seen it get too hot and I am treating it like a manual so trans heat isn't getting too bad.
For 302k she is pulling more than her weight for back to back trips.
Looks like you need some Airlift air bags in the back if you don't already have them....
Sadly that is on 864's that I just swapped in. Did not get the result I was hoping. Was considering 30mm spacers. She sits low loaded
You've got a ton of weight back there with the tongue weight from the trailer as well as the RTT, the bumper, and 4 kiddos.
I don't know how you can do that comfortably unless you're all tiny. My family of 4 grinches and moans about having to drive across town in mine, but 2 of us are over 6', and the other two are 5'-6".
We've only traveled in our LC a couple times and it is CRAMPED to say the least. However, we also have to take along a power wheelchair and a walker, and a step stool as well as our luggage and we never pack light. I have to have the air bags because of the on/off of the power wheelchair on the lift on the rear. The lift is 125 LB and the chair is 400 LB hanging about 3'+ from the rear of the hitch. Lots of overhung load.
Good luck on your journey!
We travel like this multiple times a year. I have to say the kids are great. 13,11,8 and 4 and we generally do long periods at a time.
20ftlbs seems low.
Thanks, I will round up a torque wrench and hit them all.
I agree that does sound low.
That's great! Enjoy the family travels while they're small! Do all you can! Have fun!
I had the same thing happen to me and I have a part time kit. They were all loose after completion of the White Rim Trail. I tightened all those nuts up once and they have not come loose in over 4,000 plus miles of wheeling and interstate mixed driving. I did get some blue thread lock to put on if I have to mess with them again.
