Wet Motor Misfire
North Front Range, CO
Normally when I have a misfire when the motor is wet from the power car wash it means I need new wires. After a heavy soaking at car wash.
My wires and cap are about 2 yrs old. I lightly washed the motor with the power wand at the do it your self car wash.
It was not a normal soaking like I always do, just enough to remove the dust.
When I started it it had a mis.
After several miles of driving I got home and it went away.
I didn't seal the cap with RVT like I did the first time I replaced the cap.
If the cap was wet/leaking, what would the motor sound like? Would it misfire on just one or two cylinders?
The wires are OEM and say 2006 on them.
Does this sound like a wire or cap issue?
It probably wasn't your wires in the first place...
A good check to see if you've got voltage leak that bad is to get a spray bottle of water and when it's dark (so you can see the sparks) spray the wires around the cap and wherever moisture would reach and watch for shorts to ground from the wires. The dark makes it quite a show if your wires are that bad.
I've never had this happen on my Toyotas, but I had a Rover once that looked like the 4th of July!
The 3 holes in the distributor housing make it almost like a funnel for water, almost doesn't matter if it's a light spray down or a complete washing.
Make sure the plug wires are tight against the valve cover if water gets in it will mis like crazy. I found one that was missing on a friends LC and he had another plug wire under the edge of the seal so after each bath it missed for a day or so until it dried up.
