- Joined
- Dec 2, 2004
- Threads
- 126
- Messages
- 821
Two more leaks discovered.....
Oil pan gasket is leaking, confirmed it after I found a drop of oil on the cardboard I've been using underneath to track my success (failure) in the seal project. It's leaking near the transmission dust plate.
Also, the seal that seperates the case in which the speedometer cable attaches (transfer case) is also seeping. I will have to order one ASAP. Does anyone know the part number? It's the last gasket before the output shaft, not the shaft oil seal, rather the housing gasket.
The oil pan looks like it doesn't have a gasket, I just see white sealent that pressed out during what I figure must be facotry assembly.
Thoughts on removal?
PS...when I drop the oil pan, maybe I should be proactive and install and oil return bung for a turbo? What would I need?
