Ok I just pulled the front third out with the intention of welding it up to put in the rear and swapping the lockright into the front axle. I'm probably going to have someone else do the welding since my 110 wire welder isn't quite up to snuff and I don't want to leave any slag in there from the stick welder.
There's no reason to remove the carrier from the third is there?
I know I should weld the gears to the case, but should I pull it apart and remove the thrust washers first? Will weld stick to the washers (they kind of feel like copper) or is the gap not enough to worry about?
Thanks,
Eric
Thanks,
Eric
