Ok I am going to weld up my rear diff tomorrow hopefully. I was working on it some more tonight so I could bring it in to weld tomorrow. My question is do I need to put both the spider gears back in correctly or can I put one in weld it rotate the diff then use the pinion shaft to make sure the other spider is lined up correctly and then weld the second gear. Or do I need to get them both in and lined up now. If I do need to get them both in and lined up then how do you get the second spider gear in becuase I can only seem to get one in. Either the gear drops down under the side gears or the spacer falls out or both while trying to get the second gear in place.
