weld or not to weld
NicksFJ40
Doesn’t read post longer than two paragraphs.
Western Slope, CO
Im in the process of repainting my 40, Im currently repairing corrosion and would like to know if I should weld up these cracks. The reason I ask is because the cracks are on both sides of the vehicle, so Im not sure if they are designed to relieve stress.
Thanks for the responce, I took the doors apart and welded them up. The inside support bracket was broken which caused the outer door cracks.
What would cause the A-piller or door frame to crack? After drilling the small hole, should I then weld it up?
