weird running board question
Boone, nc
Ok i'm in the process of taking off my running boards starting with the drivers side. Got to the front mount of the running boards and got the top bolt out, went to the bottom bolt and it came most of the way out but now its acting like there is a nut on the other end of the bolt. I can move the bolt in and out with my fingers so its not cross threaded and i can spin it with my fingers. Is there a nut on the end of this bolt or is somethin else goin on? Can i acess the other end of the bolt somehow?
The captive nut inside the frame may have come loose. Try and see if you can access from the other side to hold it tight. If not then you will need to try and loosen the bolt with a little pressure under the head with a prybar or the bracket itself (so that it grabs instead of slips). Worst case you may need to cut off the head of the bolt; which unfortunately may leave the remainder bouncing around in your frame driving you crazy! Good luck with this one.
:cheers:
Steve
yeah i think i'm gonna have to cut it. Hopefully it wont rattle to much or if it does it will eventaully work itself out. I"m going to leave it be for now incase someone chimes in with a magic solution. Thanks man.
awesome idea. Excuse my ignorance but what is vatozone?
