weird problem with door locks
I posted a message a couple of weeks ago about a similar issue, but coulnd't determine if it had to do with my alarm or the locking module. The strange thing about mine is that it seems pretty random, sometime I can hear the actuator fire but nothing happens, other times I can arm my alarm and the doors won't lock. Hopefully someone will respond with some ideas. Anyone have an idea what the module the from Toyota runs?
After paying closer to my problem by looking at my dash while making the hard right (not a good nor safe idea), I noticed that the "door open" light will flash on, so it must be a problem with my door sensor.
I've never opened the door, and have not noticed a sensor in the door jamb like most vehicles, but for some reason during the hard right, the sensor believes the door is open.
Anybody messed with this?
Replace the door switches. All of them. Now. It's not the use of them that causes them to fail, it's the lack of use, and, I suspect, corrosion. My rear passenger door had the worst problem, and I'm pretty sure it sees the least use out of all five doors.
Mine did this until I replaced all of them with new. I don't know whether or not it's my lack of skill at electronics, but my initial attempt at rebuilding/cleaning the switches failed to fix the issue. Some on here have been able to make that work. The switches are cheap enough, thru CDan, that it's not really worth the effort to try the clean/rebuild effort, in my opinion. Although, accessing the rear switch connections isn't a lot of fun, having to go in through the side panels in the cargo compartment.
