Weird metallic sound while turning over
Austin, TX
After a half day wheeling in 90 degree weather, my truck has developed a strange metallic sound while turning over and a approximately a second after start up. I wouldn't call it grinding, per say. Though, my experience there is limited. It is a high pitched metallic effect making the normal starter sound louder. After the engine starts and I stop the starter, the metallic sound remains for about 1 second before vanishing. After that, the engine runs normally - oil pressure is normal and unchanged. What do you all think might be going on?
JB
Sounds like the starter grinding/hanging up with the flywheel or you might need a Ford Oil filter adapter. Here's a thread:
Rattle on start up
Thank you. I think this is starter / fly wheel
I already have the adapter in a bid to stop start up rattle... didn't help.
Sounds like a starter issue.
It could also possibly be AC compressor clutch. Was the AC on when this happens?
I had one make intermittent metallic noises before it finally shat the bed
It was on. I will check in the morning with it off. Though, it seems like it would keep making noise if it were AC
Yeah, turn AC off before starting, see if it's gone.
Turn AC back on with engine running and see if the same noise happens then.
Mine made horrible noises intermittently, which made it hard to track down.
Tested it. Definately not the AC. I ordered a starter rebuild kit that includes the plunger.
If it screeches like a wild banshee in heat then it is likely the bendix not releasing properly on the starter. Plunger/contacts won't solve that issue. Either a reman denso starter or an overhaul/regrease of the bendix is in order.
cheers,
george.
cheers,
george.
I think you are probably right about that. Thanks
It turns out that the plastic bellhousing cover popped off somewhere on the trail.
:bounce::rofl:
