Weird hesitation issue
Longmont, CO
I guess this is more of a general question not specific to an 80 but I need some advice...
If my 80 sits a day or more and then I start her up on a rainy day (like today) it idles normal but when I start to drive it bogs down and sputters (imagine driving through a deep puddle at speed and water splashes up into the engine compartment and gets ignition parts like distributer etc wet). Once I limp for a little and open it up a bit and the engine gets to temp, total normal operation....
I assume it is electrical and moisture is the culprit - maybe a sequenced checklist to run down to find the source of this issue?
Thanks guys!
I would check to see if spark plug tube seals were still good and then maybe check insulation around o2 sensor wires.
I feel I noticed the same with mine just last night and it was similar to when I wash it down and get water on top of valve cover. (Tube seals) Once warmed up its fine.
Also felt like mine would not kick down an extra gear under accell
No cel - I'm due for new plugs, wires, cap, etc so I guess I'll do that to see if that remedies the issue - easy to rule out anyway
