Weird flashing dash lights
Richmond, VA
OK, so I'm still trying to figure out this new to me truck. 94 fzj80
I turned on the turn signal tonight, and all of the dash lights started to flash with the signal. Any ideas where I should start to look?
I'm guessing maybe a loose connection in the column behind the cover since it's in sync with the flasher, and doesn;t happen all of the time.
Be more specific....which lights are flashing?
On the earlier FJ80's, there are three dash lights that will turn on when the alternator output is low: Battery, Brake, and AT/P.
Could be a dying alternator (or slipping belt).
It's possible.
If you have a voltmeter on hand, measure the alternator output. Should be between 13.8v and 14.4v at 2000 RPM.
However, YMMV since you have a 94. Do you have the FSM?
:lol:
Well, go check your alternator output and post back the results. I'm sure someone with a 94 FSM will chime in...
Hmmm...I just thought of something since it's too late to go out and look at it now. The PO put a K&N filter in this thing. I have read the threads that warn to stay away. They tend to cause a low idle, correct? That would make sense since the idle was dropping as well....hmmmm....
I never had a low idle with my old K&N. K&Ns have a tendency to mess up the MAF sensor, which neither of our trucks have (we've got what's called an Air Flow Meter). But I threw it out anyway. :meh:
I'd check the intake tube before assuming it's the alternator though. If it's cracked, air gets sucked in after the AFM, causing a lean condition and low, stumbling idle.
Alt and battery are both good to go. battery was a consistent 12.9 volts and the alt was right at 14.2 with no load and 14.15 at 2k rpms.
I have an extra filter, but I'll have to check for leaks in the air tube and any vac lines. next
Definitely check the intake tube. One of the most common issues with these trucks is the notorious "tear-in-the-old-hardened-rubber-intake-tube".
