Weird electrical issue??? No start.
Vidor, TX
Two days ago, my wife gets in the truck, sticks the key in and nothing. No lights in the dash, nothing. She then pulled out the key sticks it back in and got lights in the dash. She calls me and I was only minutes away from where she was, so I was on my way. She then tries it several more times. It then started but died 2-3 seconds after running. Then the next time 10 seconds, then tried again and it ran for about one minute. When it would die, all of the electricals stayed (radio, dash lights, head lights, etc). By the time I got there it was running like normal. I checked out everything and it all seemed normal. I followed her home. Yesterday, she drove it to work and back and we ran a few errands in it with no problems.
This morning, I got in the truck and when I stuck the key in and nothing, the door ajar light was lit and the door ajar noise worked. It's almost like the battery is dead. I tried to turn the headlights on and I got a weird noise from the kick panel. Radio doesn't come on either. I've checked the battery terminals and they're as clean as a whistle. Any and all suggestions are welcomed. If you need video, I'm about to go take some crappy video with my camera. Thanks in advance.
Update: I just put it in neutral and pushed it out of the garage. I put some jumper cables on it with my car and I instantly heard the drain on my car. I jumped in the car hoping that it would just jump off. When I stuck the key in and turned it, the doors locked as they always do and the radio came on and the dome lights were at normal brightness and the dash lights work. But it still doesn't have enough juice to start it. It atleast turned over once. I'm thinking the battery itself is bad, I'm going to have it tested.
After letting it charge for 20 min. with jumper cables, it still wouldn't start. It would try to turn over. I took the battery to NAPA where it was warranted and they swapped it for me for $10. Installed the new battery and it started right up. The battery tester at NAPA showed it was just a little low like it needed a little bit of a charge. Time will tell if it was the battery.
It definately sounds like the battery. Probably a bad cell. So your battery might have something like 10 good volts, which is enough to run some accessories, but not start the vehicle. If you have a volt meter put it on the battery with the engine running just to make sure the alternator is charging it. It should read something north of 13 volts and probably closer to 14 volts. But 13.2 or so would be fine.
+1 on battery. I had the same problem before I replaced my battery. I had Sears did a battery test, and confirmed it was bad.
Thanks for the responses guys. When they tested the battery, it tested at 11 volts and said it just needed a charge. I convinced them to replace it on warranty since the battery was less than a year old. It's still very odd to me how it was intermintent the first go round. I hope the battery is all that was wrong, I hate chasing down electrical problems.
Usually Napa will run a load test on your battery before replacing.
then you'd know for sure. You should buy a volt meter, very handy for many things.
They did do a load test and it was right on the edge of being bad or being low. After I explained to them that even with the help of jumper cables it still couldn't start the vehicle, they swapped me for a new one.
Just went through some intermittent no starts myself. Turned out to be the white fusible link off the battery was hanging on by a couple of threads. A inline 20A fuse holder worked until the parts came from c-dan.
