Weird electrical buzz from driver side mirror
Touring Flerf
Hey, as per title, I have a weird electrical buzz / squeal coming from my driver side mirror intermittently.
It's got me puzzled.
Sounds a bit like the squeal you get from a MOFSET transistor in a cordless drill when you just barely squeeze the trigger.
Sometimes it will do it a couple of times a minute, sometimes won't do it for days.
It varies from a split second, to several seconds. Happens with engine on, or off.
Sounds like a stray current through the motor, but not enough current to cause the mirror to shift.
Turning off the mirror control makes no difference.
I'm wondering if it's an issue with the motor, or a problem with wiring somewhere else.
Thinking I need to change out the mirror mechanism, but if I'm chasing a wiring issue, I don't want to spend money on a mirror mechanism.
I'm wondering if the LC negative switching leaves the possibility for a stray current if there's a slight short across the motor.
Anyone got any suggestions as to what is going on?
