Weird A/C Connectors
Oregon
I bought my 1993 FZJ80 about 6 months ago. The A/C doesn't work, but it was not a big issue to me. I finally decided to take a look at it to see if I could figure out what is going on and I'm already stumped. On the low pressure side, there is a quick connect, so I figured it was R134A. However, I looked all over for the high pressure side quick connect and could not find it. When I found it, what I found was a Schrader valve R12 type connector. Seems very strange to me. However, the whole thing looks pretty factory and I haven't found much jury rigged stuff on the truck.
I believe that some time in 1993, R12 was replaced with R134A. Could this possibly be the way it came from Toyota during this transition period? I can't even connect my manifold to this without some sort of R12 adapter.
Is the low side quick connect a fitting screwed on top of the original outlet? High side is right next to it coming off of the compressor.
Is you drier up in your battery box (r12 system) or hanging down behind your bumper (r134 system)?
Mine is a pre June 1993 (r12). After 5/93 models are r134. I bought a retrofit kit from O'reillys and screwed on the low side (remember to remove the Schrader valve before doing so from the r12 fitting) and replaced the compressor with one from a 95 LC (which obviously already has the r134 high port on it) to convert to r134 (also just replaced the expansion valve, drier, and flushed system).
If you can't connect your manifold, it is most likely still the regular r12 fittings (the r134 ports are larger) and your drier is probably up in the battery box.
I think you nailed it. The high side is still right next to it coming off the compressor. The dryer is up next to the battery. I will check the build date and see if the quick connect is just screwed onto the original outlet.
Yep, you've got the r12 system. Get the retrofit kit at parts store, and snap them on (remember to remove the old Scrader valves before doing so), swap out a new drier from parts store ($15 and just ask them for 92 landcruiser parts for AC stuff so they don't give you r134 parts), and good idea to do a flush and replace expansion valve/block (I tried not to, but mine ended up being blocked with crystals). There's a good writeup on here of how to remove the core from behind glove box; not a hard job at all luckily. I'm getting mine vac'd down and charged tomorrow after doing all of that over the last week.
