Weeping Birfield
BGMachine
Working on cars I can't afford
SE Michigan
Hey all,
So I'm having an issue with my passenger (short) side birf. I rebuild the axle last year and haven't had any issues until last weekend. After returning from a day trip wheeling I noticed a bad smell and looked under the rig. Turns out birf soup had been escaping and got flung everywhere including the exhaust. I didn't notice anything the hour before when I was airing up my tires so it must've started on the way home. It was thin and greenish so I figured that it was the inner axle seal. I went in and replaced the axle seal and it seemed to work for a moment. Then I drove 5 hours home to Detroit the next day and when I pulled in I smelled a smelly smell that smelled smelly. The birf was leaking A LOT again. But this time, it doesn't seem to be a mix with diff fluid. Mainly grey so I think that it's just moly grease. Is it possible that I filled it too much (3 small tubes maybe 9oz) or do I need to redo the wipers and felt on the back of the ball? I was thinking of driving it a bit longer to see if the leak slows. If not, then I was going to clean the felt and put more axle grease on it and reassemble. Any other suggestions? Have any of you ever had this problem? Thanks for any input.
It seems to be leaking from the top portion of the ball.
