I took my 80 out last weekend for the first time.
The trails were on private land in WVA, all the trails were new with loose dirt and rocks. They had everything from mild to wild, and after two days of rain......EVERYTHING was a little wild!
In West Virginia, everything is either up hill, or it's down hill...everything inbetween is where the water settles. My plan was to take it easy the first day out but it was so muddy that the 2 and a half ton of fun I was driving seemed to want to make the easy stuff look hard (I REALLY h8mud....)
The first real trail I tried went around a pond that had kept a 60 from the night before. As soon as we cleared the pond the trail went into the woods and over some pretty good sized rocks. I start working my way through the rocks (remember, they were loose) when a rock tipped and my 80 slid into a hole, trapped a tree trunk in between the cross member and the rear axle and managed to stop its slide with the nose of my truck against a tree.... It was obvious that the only way I was getting out was a tow from behind. The truck behind me was a Discovery
, time to swallow my pride and get out of the mess. The Discovery hooked up, gave me a tug, and the tree trunk that WAS trapped behind the cross member rotated up and rammed a root up and in between the engine block and the frame on the drivers side. This was the start of a bad day.... That one tug managed to take out the oil level sensor, the front sway bar, and the steering linkage!!
I had been on the trail for almost 10 minutes
I drove the truck back to the cabin, removed the sway bar, and straightened the steering linkage and just kind of laid back the rest of the morning (remember, this was the FIRST trip out in the 80!) That afternoon I decided to take it out again, I got into some muddy steep off camber, I managed to make it out of that with only scratches and a lot of fun.
The next day brought a little drier conditions, I was amazed at what the 80 would do, it went everywhere it was pointed, and did it very comfortably. I think I need to work on the learning curve when using this truck in the mud, everything else....it's a Cruiser, what a ride!
The total carnage for the weekend?
1 sunk 60
1 rock buggy with a bent steering ram
My 80:
Sway bar
Steering linkage
Oil level sender
tail light
antenna
LOTS of scratches!
My new sliders, bumbers, and side protection worked flawlessly, absolutly NO body damage, but plenty of rubs on the armor.
I wish I had pictures, but the camera forgot to get in the truck with me
I'm trying to see if anyone else that was there has some shots.
Can't wait to get it out again!
1 sunk 60
My 80:
Sway bar
Steering linkage
Oil level sender
tail light
antenna
LOTS of scratches!
