Alright I know if this was a stock carb I wouldn' t have these issues..I got it.
Just cleaned and did a minor rebuild on my weber 32/36. Put it back on my rig, followed the pre-set adjustments that came with the rebuild kit but I can not seem to get this thing to do a low speed idle. As soon as the choke opens it sounds like it is wide open. I have adjusted the choke in both directions, done the same with the mixture screw but it won't idle. If I hold the choke plate down it will idle slowly but as soon as let it go it goes back to a faster speed The idle speed screw is not in contact with the linkage cam which I think may be the problem. I have it turned all the way in but it is not make contact with the cam. Can I get some ideas how to set the fast idle screw and fix the idle speed screw not being in contact with the cam? I am lost in the sauce!
Oh and I checked out the search option also.
