Weber 38 installation (desmogging)
I am installing a new Weber 38 on my 77 FJ40. The Weber is not compatible with the smog equiptment. I had to remove the Air injection rail (manifold) to get the Weber to fit. I need a total run down on this process. Should I plug the Air Injection holes? Is there a diagram or picture of the completed job? Based on the Haynes diagram what can I remove from the smog equipment? Should I remove the EGR Valve, VSV, ABV, Vacuum Surge Tank, VCV No.1 & 2, etc. and what do I keep?
Thanks for the help?
Welcome to Mud!
This is what I used when I did mine a few years ago. http://www.ih8mud.com/tech/smog/jimc-approved.jpg This is found under the "Technical Links" section that can be accessed via the link at the top of the page. Tons of excellent reading there.
To answer your question, yes you must plug the air injection rail holes with 1/4" NPT plugs that are available at most any Ace hardware store.
Thanks John. I have checked out the diagram and see some things are little different. Is there an explaination or run down of what is what? Is the EGR disconnected? I need help. For example, my FJ40 doesn't have a VTV from the distributor. Any advice or explanation is appreciated.
Yes the EGR gets deleted. You will need to make a blockoff plate for the intake where the EGR went. If you put the JimC diagram next to a factory emission diagram it will make lots more sense. Pretty much the entire system goes. What the diagram shows is that you run a hose direct from the inside distributor port to the advance port on the carb. I am sure there is a vacume port on the Weber for advance. You remove the VTV if you had one, which you do not, so don't worry about it.
Since you have a Weber you will not follow the diagram exactly.
