Wayfinder v7000
Humboldt Nation
For those of you with this little puppy, where do you have it mounted and where do you have the external temp sensor mounted?
I had an outside temp before with sensor mounted behind the headlight but it pegged from the flood of heat off the rad and engine when I was stopped.
Is the door jamb any good?
Thanks,
:cool:
the LX temp sensor (for auto AC) is mounted nead the USPS frame rail in front of the radiator. that should have less problems with engine heat,
a better place might be just behind the vents in the front bumper where incoming air can flow over the sensor
I have the unit itself mounted low on the DS window next to the pillar. The temp sensor I have just hanging where the winch is supposed to be on my ARB. It's well clear of the engine heat. It will pick up some engine heat or radiated heat from the bumper when stopped. No way of really avoiding that Russ. Before I had the ARB, I used one of the screws used to hold the small vent in the stock bumper and mounted it there.
