Waterproofing under the hood
So, I live in VT and with that comes an assortment of different conditions. A few weeks back I was with my buddies and attempted to go through some water and mud. I was able to clear the area, and the FJ started to sputter. I left her running in the sun with the hood open and she calmed down. On the way back through, I made it across, got cut off by another truck, hit my brakes, without clutching as a reflex and she stalled out. I could not get it started back up. I left it to dry and tried again, but no luck. Went and bought new plugs and still nothing. We finally found that the ignition coil on the is bolted on the passenger wheel well under the hood was sparking outside the wires and arcing. I have a spare truck and grabbed the coil pack from it and she started right up. As I don't have an infinite supply of starters and the such (or any more after the 1 spare I used), do you have any suggestions for keeping everything under there dry? I have read different things like ammo cans and different types of greases, but figured I would post and see what everyone says. I want to waterproof the distributor and everything that leads to it.
Looks like that was partially the culprit. I did the same thing last year but ended up dousing the dizzy which caused her not to turn over. After getting pulled out of the mud and letting her dry a bit she started right up.
Keep a can of WD-40 with you at all times.
There is a dizzy cover that will help with keeping the water out.
Other than that you need to look at any other major electricals like your ignitor. Seems like that was going out anyways if it was sparking and arcing on you.
Throw a bead of petroleum jelly around seams and points of entry .....
That's how I water proff my fj55 coil and cap on distributor .......
( THIS IS A TEMPORARY FIX Obviously) :clap::clap::clap:
