Waterproofing - Move coil?
Just went out and did a little goofing around. Read some threads on waterproofing an 80 in preparation for reasonable water crossings. I moved the ignition coil up by the PS res and covered it with a 8mm nitrile glove, haven't done it yet, but also thought i could seal off the connector areas where I cut holes in the glove with some silicone tape :hillbilly:
Before I did this, I used dielectric silicone grease on all connections and sealed the dizzy up a bit (not the drain holes). I realize that it would take a lot of work to make waterproofing perfect, just thought that moving the coil up, greasing up connections and doing a little work to seal up the dizzy a bit might make a difference.
Did I just waste an hour in my garage drinking beers and fiddling with my truck? Just want to see what some of the more experienced 80 owners have to say on the topic. All criticism welcome!! :flipoff2:
I am certainly not an expert on this subject, but it has been my experience that, other than adding a little silicon grease to the connections, keeping the coil dry is not as important as the distributor. I have gotten into water 2x now that caused my '80 to misfire, and I am pretty sure it was the distributor. before I moved up to an '80 I drove first gen Mits Montero's for many years. They have a very similar ignition set up minus the holes in the distributor. I flooded the engine bay multiple times in those trucks with no problems as long as I kept the distributor cap seal new, and I never tried to keep the coil dry.
Again, I would be more concerned about the distributor. You might think twice about sealing it, some have had problems doing that. I just made an attempt to run breathers to mine:https://forum.ih8mud.com/80-series-tech/495916-breather-questions.html One of these days I am going to take a hose to it and see how well it works.
Anyway, maybe what you have done with the coil is good. But maybe that would just trap moisture? I dont know. You'll have to let us know how it works out.
I read your thread Shawn, that's what got me started! I just didn't have the patience to do the great work you did. Judging by the responses to my thread, no one really worries about it too much.
I got the idea to move the coil from an Oz site. They mentioned putting a glove on the dizzy as well, but that is one thing I wasn't sure about. That would keep moisture from escaping the dizzy (condensation)
I think you are right .. more work on the dizzy would be the key. With the coil away from the skirting at the fender, I think it might at least keep it better protected from water .. it is a bit higher anyway.
We had a 2009 hydrolocked in our group about two weeks ago .. not a pretty sight. That got my brain thinking about my 80. I realize technique is equally important, just thought I would take what precautions I could.
Thanks for your input and the great thread you put up Shawn!
Everyone can agree that the vent holes are in the distributor for a reason, and you shouldn't permanently seal them off.
However... What about creating a "glove" that you could place around the distributor that would more or less seal off the holes, and only use the "glove" when you are on a trail that will have you fording deep water?
I've not looked at the distributor closely, so I'm not sure how feasable something like this would be, but it seems like a good option for me, as I only forsee myself crossing water that deep maybe once or twice per year.
Anyway, just an idea.
Hey Paul .. did you seal up the holes in the dizzy as well? What size of hose did you run?
I used clear silicone and went around all the wiring to make sure it had a good seal and then popped the cap off of the distributor cap and found a hose that matched the OD then drilled a hole in the Snorkel and put in a fitting that matched the hose from the distributor. That way it still got to breath but it couldnt get in any water. I tested this pretty well too going in water up over the side mirrors of the truck once, and over the hood several times.
I did this with the diffs, transmission and transfer too, but it was easy because Nissan runs them to the engine compartment for you, so all I did was finish the job to the snorkel.
Why does my 80 series bog out going fast through water? Do I need to seal off anything? Some blokes are telling me it’s my coil pack?
What about water coming in the cab, I would be worried about the computer.
I'll leave the water to the diesels.
I don't know if they're still available, but you could use a ditributor boot from a 3FE.
I have one around here somewhere that came off my '92.
In my opinion the best thing you can do is use dielectric grease on all the boots at the coil, distributor, and plugs. I would think the glove would lead to condensation problems if on there all the time. Might be good to temporarily when wheeling if you know or are pretty sure you may get into some deep water.
The distributor is vented to prevent gas build up from the crankcase, fit a vent pipe and then seal the cap joint. Cold water on a hot distributor will give condensation so it needs just a smal hole to vent.
The best all round stuff IMO is military spec spray 'conformal coating', for want of a better description it is spray plastic, as it settles it dries as if you had shrink wrapped the ignition system.
Failing that get a diesel. :flipoff2: :p :D
Land cruiser water site:youtube.com - Google Search:
Link works but you may need to visit youtube to view?
Regards
Dave
