- Joined
- Feb 24, 2010
- Threads
- 2,226
- Messages
- 2,226
The LEDP10W-240E LED High Intensity LED Light Bar from Larsonelectronicsllc.com closes the gap*between LEDs and traditional metal halide lamps with 20,640 lumens of high quality light output.*Designed for extreme conditions and fully waterproof, these high performance LED light bars offer*performance comparable to HID light fixtures without any of the high heat or fragile construction that*can [...]
The LEDP10W-240E LED High Intensity LED Light Bar from Larsonelectronicsllc.com closes the gap*between LEDs and traditional metal halide lamps with 20,640 lumens of high quality light output.*Designed for extreme conditions and fully waterproof, these high performance LED light bars offer*performance comparable to HID light fixtures without any of the high heat or fragile construction that*can make HID lighting a less then reliable lighting option in commercial work conditions.
The LEDP10W-240E LED Light Bar is designed to provide an extremely rugged and long lasting*alternative to traditional forms of industrial and commercial HID lighting options. Producing over 20,000*lumens of high quality light output, these extreme duty LED light bars produce light output that matches*the light output of comparable metal halide lamps, yet is far more durable, more reliable, and last*longer. Unlike metal halide and other HID lamps which require a warm up period before they reach*full intensity, the LEDP10W-240E produces full light output the moment it is switched on. Additionally,*unlike HID lamps wh
ich must cool down between on and off cycles, this LED light bar can be switched*on and off without any need for a cool down period in between. Constructed of extruded aluminum*with an unbreakable polycarbonate lens, waterproof to 3 meters of submersion, and fitted with twenty*four CREE XLamp MC-E®10 watt LEDs, these light bars can easily withstand the demanding conditions*found in industrial work applications or offshore marine operations. The CREE LEDs in these units*provide excellent light output with over 20,000 lumens of light produced at a color temperature of*6000K, making these LED lights well suited for applications which require lighting that provides above*average detail rendering and contrasting. These lights contain advanced LED drivers utilizing pulse width*modulation technology to allow operators to connect dimmers and pulse controllers in order to cause*the lamps to dim, flash or strobe as desired. These same advanced drivers also provide built in voltage*management and active heat control which allows these units to be operated with any voltage ranging*from 9 to 48
VDC and helps to keep the LEDs running cooler for a longer operating life. These LED*light bars can be configured for spotlight or flood beam style output, and spot light configurations will*produce a beam reaching over 1400 feet in length. These light bars also include heavy duty mounting*hardware that provides adjustable installation options and vibration reduction, allowing operators to*install them on a wide variety of vehicles, boats and heavy equipment. These lights are particularly*popular with commercial fisherman and industrial operators because of their very high output and*ability to withstand demanding and abusive conditions.
“With lower power consumption and less heat generated, the LEDP10W-240E is a more versatile and*economical solution for brighter working areas than metal halide and high pressure sodium lamps,”*said Robert Bresnahan of Larson Electronics’ LLC Larsonelectronicsllc.com “At Larson Electronics’, we*continue to develop new LED lights to help our customers extend their field of view for work, safety, and*reliability.”
Larsonelectronicsllc.com produces a full range of LED lights, LED work lights, LED boat lights, intrinsically*safe LED lights, and explosion proof LED lights. The Larson Electronics family of brands can be found on*Magnalight.com, LXFlashlights.com and Larsonelectronicsllc.com. You can also call 1-800-369-6671 to*learn more about all of Larson Electronics’ lighting products or call 1-214-616-6180 for international*inquires.
Link
Link
