Water Water Everywhere...
But not a drop to drink.
98 4Runner with 165k. Leaking all over the front of the engine. Water pump went out unexpectedly. Checked the forums and have a good idea what is needed just have a couple questions.
1) Is it worth it to get the 2 idler pulleys? Pretty expensive even from CDan.
2) What about the tensioner? I can get the snap-on tool but tensioner runs about 30 bucks?
List so far:
Pump
Pump gasket
Belt
TStat
Tensioner
What do you all think?
Is that enough?
List so far:
Pump
Pump gasket
Belt
TStat
Tensioner
Is that enough?
With your mileage it's probably worth your while to replace everything. both idlers, the tensioner the seals, pump etc etc etc.
Don't want to have to open it up again for something like that. Should be good again for at least another 165,000 miles. :)
-Timing components and water pump-
13568-69095 Timing Belt
13503-62040 Idler #2
13505-62070 Idler #1
13540-62021 Tensioner
90311-38051 Cam seal
90119-16006 Crankshaft damper bolt
90311-40022 Crank seal
90916-03075 Thermostat
16325-62010 Thermostat gasket
16100-69398-83 Waterpump
links to writeups here...
https://forum.ih8mud.com/95-gen-toyota-trucks/341631-3rd-gen-4runner-faqs.html
Here's my part list
liljlandon said:
Heres the final list of parts...
Rock Auto:
6 Plugs - DENSO 3194
V/C Gasket Kit W/tube seals and grommets - Beck Arnley 0361583 (036-1583)
Radiator Hose Upper/Lower - Dayco (who manufactures tensioners for lexus japan!?) 71794/71695
Crankshaft Seal - Timken 224020
Timing Belt/Water Pump kit - AISIN TKT005
Toyotapartsales.com
12204-62010 PCV valve
19037-62010 Spark plug cables
Plenum Gaskets - No part numbers
Oil Filter for 4.0 V6
New sticker for "3400 DOHC" on timing cover.
From local stealership
-Antifreeze
Time to wrench :grinpimp:
The rockauto aisin kit will save some $$.
Thanks for the great parts list raydouble...how hard is it to replace the cam seals?
Not difficult at all. Just need to make sure not to score the camshafts, usually pretty easy to remove with a flat screwdriver punched through the middle of the seal.
Note seal depth before removal.
Liljon, how much does the rockauto kit cost?
I used to have a list of what it cost to order online from like, 1sttoyotaparts or toyotapartspeople. Looks like I'll have to do some comparison.
