Anybody have a good remidy for stubborn water spots? I have had some water spots on my hood that just will not go away. I serched here but did'nt get a good answers. I have tried various rubbing compounds but nothing has worked. Any ideas before I buy about every polishing agent on the shelf??? Thanks
Yes, you should use a clay bar and then a paint sealer and then Carnuba. Reapply the Carnuba wax as often as needed. And don't let your water from the garden hose sit and dry on the hood as it will leave deposits. After your finishing rinse with the spray nozzle, remove the nozzle and just let the water pour out of the hose onto the paint surface and it will help the water to shed off rather than leaving spots. Then you can use a California squege to remove the rest of the water and then dry with micro fiber towel.
Thanks for thr thoughts guys...I will give the claybar a try.
The water spots were on it when I bought it. It is a Denver vehicle and when I picked it up it looked like it had been dusty and then rained/sprinkler?? on it. Big puddles of dirt. When I washed it the first time and dried it off I could see the spots. What a pain. I will post up after trying the claybar.
Wash the car, clean the paint, use claybar, polish the offending spots off. Polish will remove the spots. After all is done, then you cover with some good carnuba wax.
carnuba is the best but it doesn't last very long. I've been using Griots Garage Paint Sealant and it's kept up great for much longer. Try it out! griotsgarage.com
Zaino is another batch of top notch products. Carnuba doesn't last very long in the desert heat but I have had great results with this stuff. zainostore
I hate to be the decenter here but, fill a spray bottle with water and add about 1/4 cup of Vinegar to it, make sure you are in the shade and just spray it on and wipe them off.. We have a bottle mixed up that we keep in our boat and it removes them every time.. plus its cheap!!
later Bret
later Bret
