Rod,
Sounds like your rocker panel drains are clogged. The sunroof drains into the rockers and car washes definitely require the sunroof to drain.
Two thing to do: First, there are plastic plugs in the lower surface of the rockers. Remove them and let the water drain out, but put them back afterward. Second, Along the inside of the pinch seam on the bottom of the rocker, you'll find several areas where the seam appears purposely separated. These are drains and they are probably clogged. I found that a small zip tie will fit into the opening and when moved around in there will unclog it. You may find some more water drains out when you do this.
That's my call. FWIW
