water sloshing sound
Arkansas
I was driving my '92 LC today and noticed when I hit my brakes that I could hear water sloshing. When I got home I noticed a rubber plug just behind the front wheel and when I pulled it out there was a couple gallons of water that ran out. I left the plug out for right now. What is going on? Is there not supposed to be a plug there? Is there a leak somewhere? I noticed that there is 3 or 4 plugs along the rocker panel on both sides of the vehicle. Should I remove all of these? Thanks!!
BB,
This is where the sunroof drains go. If you look along the standing seam/pinch weld next to the plastic plugs, you will find small openings in the seam. Take a smallish zip tie or some thin object with similar characteristics and poke it into these openings and work it around a bit. These are the drains for the rocker. They get clogged from road grime and such. The plugs work, but I don't know that I would want that many openings of that size into my rocker for extended periods.
HTH
I had the same problem:o
Zip tie sure sorted it out, i have to clean it out every few months:) just to keep it from filling up again!
Thanks... I knew I could count on you guys!!
