Water pump
Lincoln ca
Has anyone rebuilt an early water pump before. I was going to try to rebuild, or at least clean up, the pump from my 73 but I broke the wire clip. I’m not even sure what that clip did or how to disassemble this thing. Anyone have any tips or knowledge on this?
Has anyone rebuilt an early water pump before. I was going to try to rebuild, or at least clean up, the pump from my 73 but I broke the wire clip. I’m not even sure what that clip did or how to disassemble this thing. Anyone have any tips or knowledge on this? View attachment 3059338View attachment 3059339
this is a highly labor intensive topic job scope
where are you sourcing a OEM toyota water pump kit still , i was under the thought they were long since disc. / NLA
the shaft will have scoring from the seal and 50-60 years of age and time ,
NO speedy sleeves for this , i have ever seen ?
i suggest you consider a practical made in JAPAN solution here below , comes with oem toyota genuine parts gasket , MY water pump is a KIT form product that includes ALL related mounting hardware and gaskets
needed bypass hose kit separate ...fyi
OEM period correct mounting hardware is also JAPAN made
Yeah I’ve had some friends suggest the
same thing. I’ll just order one. Thanks!
