Water Pump Shaft Failure
California, USA
I saw Poser mention this in the post about the radiator that kept failing and it made me think.
How many of you guys have had your water pump shaft fail and subsequently send your fan into your radiator. It happened to me almost exactly a month after replacing the dented and leaking radiator the PO had in my rig :mad:
I'm not looking for any hard data or anything, just wondering how often this seems to happen.
My friend Murphy says "Often!"
Kirk
Once on my 71FJ40 blade went through the Fan shroud and scuffed the fins on the radiator Lucky me ? and once one a 84 FJ60 distroyed everything the radiator and fan and the fan shroud and was 300 miles from home on the last day of my vacation :mad: JC
my64fj40 said:
Damn...
I think I'll go buy some loctite now...
Loctite wouldn't have helped in my case. The actual shaft coming out of the waterpump sheared off inside the pump and the whole fan and fan clutch assembly shot forward into the radiator. :eek: Started dumping coolant immdeiately. "Luckily" I was right next to a parking lot, and only 4 blocks from home.
projektdotnet, was that a metal fan on his 40? I can't imagine my plastic one actually making it through the hood.
My first car was a 71 firebird and a real POS, but at 16 hey it was way cool. I lost the waterpump and replaced it. I then had the radiator blow. It was not until then that the radiator shop guy pressure tested my cap and found the issue before I lost the heater core, the only item left that could fail. I know this is not a 40 water pump story but it is interesting how a $7 radiator cap can destroy so much, so have caps tested when something fails in the cooling system.
Pete
Pete
Better yet, test them as part of periodic maintenance. Part stores will test them for free.
The testers are not cheap ($75 up), but considering the damage that can occur, that's cheap!
Besides, who among us doesn't like buying tools?:cheers:
Kirk
