Water Pump Replacement
Camden, SC
Just took the radiator off my 92 LC :bang: and don't want to have to go through that again......EVER! Just thought I would replace the water pump while I can get to it. It appears to be a little above what my non-mechanical mind can handle. I was looking for a good step by step thread for water pump replacement and can't find one. Can anyone point me in the right direction?
Yes, first off, get a FSM (stands for Field Service Manual). Then get some help, sounds like your a beginner at wrenching. This thread makes it sound sort of involved:
https://forum.ih8mud.com/80-series-tech/121082-3fe-water-pump.html
Edit: Factory Service Manual, NOT Field Service Manual. Sorry for error!l
:lol:
The radiator is nothing compared to the water pump.
I wouldn't replace it "just 'cuz you're in there" unless you really are prepared: New OEM pump (no WAY would I replace that part with anything aftermarket) and gasket, all hoses going to the pump, etc.
It's not really "difficult", but it is very tedious and time consuming: lots of parts have to come off, things need to be removed in the right sequence, hopefully no bolts are frozen/seized...
Username "jon held" may have posted a write-up, or else you really should get the FSM.
Cheers,
Curtis
Field Service Manual :eek:? I have been calling it a factory service manual this whole time :whoops:.
I learned something new today
No, you were correct. The correct term is " Factory Service Manual" not "Field Service Manual" .
Anyone that has an 80 and does their own maintenence should have one.
Pete
Pete
My apologies to all concerned. Being a field service technician for 25+ years does something to your perception when you see an acronym that starts with an 'F'. Factory, factory, factory, not field --- I knew that-argh!
Sorry for the hijack.
I can tell from the previous posts that the water pump replacement on a 91-92 80 series is a pain. Can anyone comment on this same job on the later series 80s (93-97). I think I have this one in my future. Thanks.
