Hey guys, I have a 78 FJ40 in the shop I'm working on. It's been rolled and I'm replacing the front clip with parts from a 77 donor. Well, the 77 had power steering on it and the customer wants to swap it over to the his 78. so I torch out the rivits and swap over the gear box, bolt the pump on (wich looks to be a mini truck pump with an aftermarket bracket) and the pullies are not lining up. The 77 donor had a larger diameter hub on the water pump so I could not re-use the pully from the donor. I can swap the pumps but this motor's old and crunchy so I would perfer to buy a new pump. Does anyone know what pump I need to order to make the larger diameter pulley work??? Was there 2 different pumps? OR, since I have the gear box what would be a good kit to just put a new pump and bracket in?
Jason
Jason
