Water Pump Leak
Orlando, Fl
so, we finaly got this beast of a rig to idle without backfiring, and to run smooth, and just then, water/rad fluid starts comming out from behind the fan blade, so we took the rad out, and the front bib down, and were not sure what to do? why would it leak from the fan.....
Jonathan / SandRider - Ryan / BigBlue
Not from the fan, but from the pump...
Look for the little hole on the bottom of the pump....it will most likely be wet there...
Good luck!!
Oh.....OEM pump....CDAN!
-Steve
Sand Rider asked: why would it leak from the fan.....
Maybe because the pump shaft bushings/bearings are shot and there's enough clearance for the coolant (which is under pressure due to the heat: PV=nRT and all) to be forced past the clearance and out the front of the pump. That's where the fan attaches.
