Water Pump Bearings?
Believe its a sealed unit. Must buy the whole WP
If you're hearing something, bet ya a cup of coffee it's just the belt tensioner pulley...
DougM
DougM
No I just think it's leaking. I see they sell re-manned ones so I figured there can't be much to them.
Without grabbing my manual, is there a way to replace the shaft seal you think is leaking, or are you saying the bearings are causing the leak?
DougM
When I replaced my water pump (turned out probably needlessly) I couldn't figure out how it could be taken apart.
The 80 series water pump is the biggest, heaviest duty and most expensive water pump I've ever seen. At least for an engine in this size class. Appears to be a double bearing unit at least and is probably designed to last the life of the engine or darn close to it.
http://www.brian894x4.com/images/FZJ80coolingprojectx006.jpg
