Water Fording
I have read many good posts with all kinds of advice on making the LC water ready.
Extending breathers on the diffs to running an airintake to from the interior of the cabin to the distributor.
Anyone have a step by step checklist that they could share?
Thanks,
How deep are we talking here?
If you're starting to worry about your distributor, you REALLY need to think about your air intake. Snork it, and run your distrib vent to your snork.
From a very old thread (2003) found by using Keyword=fording
OK here goes...
First, credit for this post goes to a guy by the name of Pieter. He died suddenly about a year ago so he is driving Cruisers in heaven now.
Tips in fording water:
Both my cruisers have a fording depth spec of 70 cm or 27.5". I have never measured it, but I think it's the level where the axle and transmission breathers end.
I've driven through much deeper water (coming over the hood) and with the proper precautions and modifications I think you can easily prepare it for something like 40" fording depth
1. extension of breather lines. Purpose: prevent water entering the driveline and mixing with oil. To my knowledge, the following items have breather hoses:
front and rear axle, transmission, transfer case, diff lock actuators front and rear, winch. You would replace the attached hoses by longer ones and run those to a high location in the engine bay or, like I've done on the 74, drill holes in the air filter housing, fit with nipples and connect the hoses there.
2. move the air intake higher by adding a snorkel. Purpose: prevent water being sucked in the engine and damaging or destroying it.
3. after a water crossing, lubricate driveline and steering. Purpose: minimise water ingress and deterioration of grease. Keep a grease gun with the right grease (NLGI.2) handy so it is not put off. Use grease with the best water repellant properties (typically with Molybdeen-disulfide doping).
4. If you cross water regularly, you probably want to repack the wheel bearings more often (half the interval, and check if grease shows water contamination).
5. if you have a petrol engine, waterproof the ignition components. Seal as much as possible or, minimum spray WD40 or similar on the electrics that will see water (immersion or splashed).
6. Check sealing of lights. Water ingress quickly corrodes reflectors. I have all my lights sealed with silicone. Have not seen a problem with pressure differences (opinions vary). Most Toyota lights have a vent tube that points downward. Add a short hose to extend it further.
7. Check the fuel filler cap for tightness and that the pressure relief valve works.
I may have forgotten a few details, but this will prevent the more serious problems.
Then there are a few driving tips:
  • Switch off headlights and wait a couple of minutes with the engine idling before entering the water so hot items can cool down a bit.
  • Walk the crossing so you know / feel what is under the water (rocks, holes, bottom consistency).
  • Switch the heating / AC to off and the selector to recirculate to prevent the fan sucking in water.
  • Don't enter and exit the water always at the same location. A hole will develop.
  • Put up markers to indicate your best line to follow
Cheers, Pieter
HDJ100, HZJ74
-B-
2X
Because you don't want to end up in pics like THIS
or this
not only did these drivers suffer from bad air intake position, but also bad entry strategy.
:cool:
Besides, they do not have Cruisers!!! ;)
