washer fluid problem
DC
Website
www.instagram.com
ever since i stole my truck from my dad, ive only been able to wash the windshield. when i turn the switch for the rear washer (i guess its separate for that one, since the other button runs the front sprayer and wipers) the front sprayer turns on but none of the wipers do? what should be going on with each of these switches, and what is probably wrong?
The front washer is controlled by the push button on the end of the wiper stalk. Pushing/holding the button will spray the front windshield and run the front wipers until you release the button. The rear washer is triggered either by twisting the rear wiper section of the stalk downwards (sprays the rear glass, no rear wiper action) or by twisting it up past INT and ON (sprays the rear glass, wiper stays on until you turn it off).
I wish the wiper turned on with the rear spray when you twisted downwards as just spraying the glass gets me two thin clean lines and not much else. I also wish there was a "mist" function for the fronts. Oh well :meh:
After reading your first post again, it sounds like your diverter valve is going out. It is an electrically switched valve that sends fluid to the rear washer when you trigger it. Search for "diverter valve" to find some pics and better info!
My diverter was leaking like mad. I sealed the edges with JB-Weld and it has been working fine for 3 years. You can also easily bypass the diverter by connecting the hose for the front windshield directly to the hose from the pump. You wil lose your rear washer though.
