Warning lights test
Eastern Idaho
I have a '97 FZJ-80. When I go to turn the ignition to the "on" position only a few lights go on. Which lights are supposed to turn on for a few seconds to let me know that the bulb is good? I am curious because my "low oil indicator" does not light up. I would like to know what else is missing?
Thanks,
here is the a list of the lights, one way or another you should be able to test them, there is a post here that lists the lights that are lit with key on engine off.
air bag, ABS, AT/Oil temp, CDL, blank, check engine, seatbelt, cruise, high beam,__________ space________brake, low oil, A/TP (tecase neutral wile trans in park) blank, front locker, rear locker, air filter clogged (not lamped in the US), and finally door open
