Warn spot lights
Mudder
Between states
So I have a pair of old warn spot lights. These things work great. I managed to roll my truck and they came out almost fine but for the glass getting pushed in. Has anyone seen these before or know how to get then apart and can tell me? I'd like to get them fixed so I can get them on my new rig. Here's a pic of 'em I can supply more info if needed.
I think you have to do the following:
Remove the screw that holds the outer ring to the body.
Use a wedge like a screwdriver to pry the outer ring from the body
Hopefully your lense and reflector will pop back into place. If not, you might be able to find a sealed beam lamp as a replacement.
Good luck
Thank you so much 77LCFJ40. Took a flat head and popped it off. I didn't want to have to replace them. Thank you again.
Cool.
Did the lense and reflector go back into place and work?
I haven't put them back together yet. Still letting them dry. I know the lights worked as they stayed on after I rolled my truck and I had to turn them off.
Got everything put back together. They work and now I just need to remount the bumper then they'll be back on it.
Great to hear it.
