Warn Series 12...will it fit?
East California
Will the Warn Series 12 winch fit the ARB bumper like the M12000? Also, what's the difference between a "self recovery" winch (M12000) and this "Industrial" winch?
Pics for views.
The drum is a lot smaller, so I'm guessing it holds less cable. Definitely better than no winch, make it fit!
In the link above it says it takes 126' of 3/8" wire rope. Does anyone know how many bottom mounting holes the M12000 has? This one has 8 (2 in each corner).
The guy is selling it for $400. Worth it or not? Not sure if I like how that hook is attached though and a replacement rope is ~$250.
A standard M12k holds 125 feet of 3/8, but that drum looks smaller. Maybe it's just the picture.
A new wire rope is $75 or so. The synthetic is pretty expensive.
One major difference between current industrial 12K and truck 12K warn winches is motor size and power. The industrial winches use a smaller 2.5 h.p. motor, while the truck winch uses a 4.6 h.p. motor.
However, I'll bet the duty cycle of the industrial winch is longer. Probably due to less heat build up of the smaller motor and slower line speed. A selling point to industrials is a long lasting winch that can keep winching. A selling point to consumers are things like fast intitial line speed.
Interesting that they list the duty cycle of the industrial winches, but not the truck versions, so it's impossible to compare. However, they do list line speed and the industrial winch has half the line speed at zero load as the truck version.
But what's interesting is that the industrial winch's line speed actually improves over the truck winch as the load increases. Not by much though.
But surprisingly, the smaller h.p. industrial winch seems to pull a higher load in terms of amperage than the industrial version.
In comparing the prices of the two, the industrial winch seems to be at least several hundred dollars more and doesn't include wire cable, which would probably add another few hundred to the overall cost diffrence.
So, it's possible the industrial winch is a better built over all winch, but initital line speed is slower, while load speed is comparable. The industrial winch seems to have a higher power requirement, which could be a consideration. Whether it uses the same foot print, or any size differences, I don't know.
Also, that's an older winch, so it's hard to say if an older industrial winch is better than a new truck winch. Also industrial winches tend to be used far more often than a truck winch. A truck winch might get used once or twice it's entire life. It's a good bet an industrial winch was used on a regular basis and might need to be overhauled or might even be junk now.
The pictures seem to indicate it at least spent the last part of it's life as a trailer winch, which means it may have been used on a regular basis, but the loads on the winch were probably minimal.
Here's warn's truck winch page for the 12K winch...
http://www.warn.com/truck/winches/src/M1200.shtml
And their page for the industrial 12K winch....
http://www.warn.com/industrial/winches/series_12dc.shtml
Hope that helps....
Not to mention, the gearing on the industrial winch is lower as well. My initial guess is that if the motor ever went bad, you could just swap in a 4.6 amp motor and pick up the line speed a little. Sounds like a good deal to me.
They make both 12v and 24v versions. This one is 12v.
Your picture looks like a short drum Severe Duty Series 12 which will spool under 90' of 3/8" due to a larger diameter/smaller width drum:
attachment.php
Not the longer drum Series 12 which you linked too, neither of which have the 10"x4.5" mounting pattern typical to a recreation winch:
