Warn hub rebuild
Albuquerque NM
I ordered rebuild kits from SOR - in this case SOR-RY.
First these are for the 78 FJ40
Kits did not include rubber gaskets between the handle and cover, nor the o-ring nor either of the spacers.
The Warn 7309 does not look like it includes these either.
Short of new hubs - help!
Skipper
I've never seen kits include the rubber oring for the knob. Unless you soak it in gasoline or something, the o-rings should be okay. Not sure what rubber seal and spacers you are referring to? There is a paper gasket between the hub body and the hub face and between the hub body and the wheel hub. And two dowel pins between the hub body and the wheel hub, but those are oem, not warn.
