Warn 9.5xp will not free spool?
Call *Warn 800/543-9276 - Ask for Ron Hoffman x3031 or Augie: x3205. Both are very helpful.
I had a 9.5ti with a similar problem. My lever turned, but the drum would not freespool. Turned out water was coming in through the free spool lever and running inside. I had rust inside the case under the lever, inside the drum, and inside the motor casing. Augie sent me a replacement lever that had the washer glued in place, with extra sealant under the washer to prevent further water incursion. The winch had to be disassembled, derusted, and reassembled.
Thanks for the numbers called Ron today and he told me what was wrong and how to fix and to call him if it does not work. Warn Custormer Service great A++++++++ :clap: Thanks again for the info:cheers:
some times i have to move my drum a little bit by hand to get my winch to free spool and run it electronically to re-engage .
but i have a totally different animal then a warn 9.5xp .
sounds like you have it figured anyway .
You're welcome south. What did Ron say was the problem? Can't keep us in the dark!
