Warn 8274 Aftermarket Bearings and Seal PN’s
Louisville, KY
Hi all. I’m rebuilding an 8274. I am replacing the majority of the bearings and seals but want to avoid the ‘Warn Part Tax’. I have found the ‘aftermarket’ pn and sources for most of the bearings but need the seal pn’s.
——-BEARINGS———
Upper Needle Bearings (2): Koyo B-68
Upper Armature Bearing (1): WTW 6203RS
Brake Ball Bearings (21): 3/8” dia ball bearings
Clutch Detent Ball Bearing (1): 1/4” dia ball bearing
Brake Shaft Support Bearing: IKO BAM 1316
——SEALS——
Brake Shaft Radial Seal: ???
Brake Shaft O-Ring: ???
Drum Radial Seal: ???
Please post any details you have found and I’ll update above.
