Frustrations are building...
I have a 1975 FJ40 that we swapped a 1988 FIE into a couple years ago.
Followed what info I found on here for the swap, wiring and de-smog tech.
It starts cold but if I shut it down to say run into the store, it won't start when I come out... but if I wait for 15/20 minutes, it'll start.
It'll jump start though.
Things I've done:
*Installed new plugs/wires
*Replaced both fuel filters (pre filter inline of pump and after)
*Replaced dizzy on recommendation of 'those that know' because they said it was a "common" dizzy issue. Quoting the plates get hot and won't allow enough ohms to pass to ignition/spark.
*Replaced the coil also due to having a rather small spark while cranking coming from the coil.
Nothing has made any difference...
I'm asking for input because my next step is to replace the igniter and I don't really care to keep throwing good $$ after bad.
Things I've done:
