1997 fj80 w 140k. Runs drives great. Problem..maybe.
... after running to work 20-30 miles on the highway the truck's idle (when stopped at a light) will dip slightly below 600rpm....a/c is off... below 600 the idle is slightly rough. All maint. is up to date. Idle is normal at all other times including when a/c is on. Is this a problem....if so where do I start looking.
Thanks alot for your time
Nathan
... after running to work 20-30 miles on the highway the truck's idle (when stopped at a light) will dip slightly below 600rpm....a/c is off... below 600 the idle is slightly rough. All maint. is up to date. Idle is normal at all other times including when a/c is on. Is this a problem....if so where do I start looking.Thanks alot for your time
Nathan
